Wire wound resistor value
I want it to be correct, If you say it is not important here that's fine but where is the chart for these resistors for the future?
Is it still body end dot?
Thanks
Kirk
Wire wound resistor value - by OldRestorer - 03-09-2015, 05:52 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 07:51 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 08:23 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 09:03 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 09:25 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 11:16 PM
RE: Wire wound resistor value - by Ron Ramirez - 03-10-2015, 09:12 AM
RE: Wire wound resistor value - by OldRestorer - 03-10-2015, 09:26 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
