Introduction and two Philcos
#32
<Speaking of resistors, how do I tell the resistance of a dogbone resistor?
Well those resistors are called Body End Dot resistors or BED resistors.The first band if you will is color of the body. The second band is the color of the end. And the last band is the color of the dot. They use the standard RMA color as the newer resistors with bands
Hope this helps
RE: Introduction and two Philcos - by morzh - 03-07-2015, 06:27 PM
RE: Introduction and two Philcos - by klondike98 - 03-07-2015, 06:53 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 07:11 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-07-2015, 07:17 PM
RE: Introduction and two Philcos - by klondike98 - 03-07-2015, 08:15 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 09:08 PM
RE: Introduction and two Philcos - by Mondial - 03-07-2015, 09:48 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 10:04 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-07-2015, 10:11 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 11:17 PM
RE: Introduction and two Philcos - by morzh - 03-08-2015, 12:18 AM
RE: Introduction and two Philcos - by Radioroslyn - 03-08-2015, 12:24 AM
RE: Introduction and two Philcos - by Joe Rossi - 03-08-2015, 08:17 AM
RE: Introduction and two Philcos - by Mondial - 03-08-2015, 09:30 AM
RE: Introduction and two Philcos - by klondike98 - 03-08-2015, 12:31 PM
RE: Introduction and two Philcos - by Mondial - 03-08-2015, 01:28 PM
RE: Introduction and two Philcos - by Mondial - 03-09-2015, 08:20 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-09-2015, 08:59 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 12:02 AM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 12:26 AM
RE: Introduction and two Philcos - by Warren - 03-10-2015, 02:44 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 10:10 PM
RE: Introduction and two Philcos - by Mondial - 03-10-2015, 11:29 PM
RE: Introduction and two Philcos - by Warren - 03-11-2015, 02:43 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-11-2015, 06:40 AM
RE: Introduction and two Philcos - by klondike98 - 03-12-2015, 08:37 PM
