Ecap help
unknown maker radio. 2 ecaps in cardboard box. One goes to chassis and pin 4 or 5 of the 25L6. Other goes to a terminal strip and pin 3 of the 25Z5. Any ideas?
Kirk
Ecap help - by OldRestorer - 03-10-2015, 01:56 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 02:50 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 03:00 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 03:02 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 03:20 PM
RE: Ecap help - by Carl Travis - 03-10-2015, 04:00 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 04:08 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 04:35 PM
RE: Ecap help - by morzh - 03-10-2015, 05:03 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 09:59 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 10:25 PM
RE: Ecap help - by Radioroslyn - 03-10-2015, 11:40 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 11:42 PM
RE: Ecap help - by morzh - 03-10-2015, 11:53 PM
RE: Ecap help - by Arran - 03-11-2015, 03:53 AM
RE: Ecap help - by Radioroslyn - 03-11-2015, 06:47 AM
RE: Ecap help - by OldRestorer - 03-11-2015, 12:03 PM
RE: Ecap help - by PAradiogeek - 03-11-2015, 06:27 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 10:04 AM
RE: Ecap help - by morzh - 03-12-2015, 11:06 AM
RE: Ecap help - by sam - 03-12-2015, 11:51 AM
RE: Ecap help - by PAradiogeek - 03-12-2015, 11:57 AM
RE: Ecap help - by Arran - 03-13-2015, 01:01 AM
RE: Ecap help - by OldRestorer - 03-12-2015, 12:42 PM
RE: Ecap help - by morzh - 03-12-2015, 02:55 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 03:11 PM
RE: Ecap help - by radiohenry - 03-12-2015, 03:47 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 05:50 PM
RE: Ecap help - by radiohenry - 03-12-2015, 07:12 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 08:33 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 10:23 PM
RE: Ecap help - by radiohenry - 03-14-2015, 08:12 AM
RE: Ecap help - by OldRestorer - 03-14-2015, 11:45 AM
RE: Ecap help - by morzh - 03-14-2015, 11:59 AM
RE: Ecap help - by OldRestorer - 03-14-2015, 12:14 PM
RE: Ecap help - by radiohenry - 03-14-2015, 12:32 PM
RE: Ecap help - by morzh - 03-14-2015, 03:19 PM
RE: Ecap help - by OldRestorer - 03-14-2015, 05:29 PM
RE: Ecap help - by morzh - 03-14-2015, 06:44 PM
RE: Ecap help - by OldRestorer - 03-14-2015, 09:06 PM
Users browsing this thread: 18 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7184 online users. [Complete List]
» 1 Member(s) | 7183 Guest(s)
