UPDATE: Tubes tested. Canadian Philco Radio: ID and repair needed
Ok check to see if you have HV on those pin with the set on. Also disconnect one side of the speaker measure the resistance of the spk v.c. and the secondary of the output transformer.
RE: New Canadian Philco Radio: ID and repair needed - by Radioroslyn - 03-10-2015, 06:02 PM
There are currently 5901 online users. [Complete List]
» 2 Member(s) | 5899 Guest(s)
