UPDATE: Tubes tested. Canadian Philco Radio: ID and repair needed
Do you see any glow from the filaments? There going to be pretty dim but visible in a dark room.
RE: Update with Pics, New Canadian Philco Radio: ID and repair needed - by Radioroslyn - 03-10-2015, 10:15 PM
There are currently 5933 online users. [Complete List]
» 2 Member(s) | 5931 Guest(s)
