Ecap help
Ok I am at the house and just opened the ecap. There are 2 large caps, each with one wire going directly into the cap. The other wire on each does not go to the cap directly but is attached to a thin metal strip going into the other end of the cap. The one caps wire is going directly into the cap is grounded to chassis. On the other cap the wire going directly into the cap is going to a terminal strip. What should the mfd be for these?
Any ideas?
Wrong schematic I guess?
someone said the 979 schematic had the block with 2 ecaps in it but schematic is impossible to read.
Kirk
Ecap help - by OldRestorer - 03-10-2015, 01:56 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 02:50 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 03:00 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 03:02 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 03:20 PM
RE: Ecap help - by Carl Travis - 03-10-2015, 04:00 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 04:08 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 04:35 PM
RE: Ecap help - by morzh - 03-10-2015, 05:03 PM
RE: Ecap help - by PAradiogeek - 03-10-2015, 09:59 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 10:25 PM
RE: Ecap help - by Radioroslyn - 03-10-2015, 11:40 PM
RE: Ecap help - by OldRestorer - 03-10-2015, 11:42 PM
RE: Ecap help - by morzh - 03-10-2015, 11:53 PM
RE: Ecap help - by Arran - 03-11-2015, 03:53 AM
RE: Ecap help - by Radioroslyn - 03-11-2015, 06:47 AM
RE: Ecap help - by OldRestorer - 03-11-2015, 12:03 PM
RE: Ecap help - by PAradiogeek - 03-11-2015, 06:27 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 10:04 AM
RE: Ecap help - by morzh - 03-12-2015, 11:06 AM
RE: Ecap help - by sam - 03-12-2015, 11:51 AM
RE: Ecap help - by PAradiogeek - 03-12-2015, 11:57 AM
RE: Ecap help - by Arran - 03-13-2015, 01:01 AM
RE: Ecap help - by OldRestorer - 03-12-2015, 12:42 PM
RE: Ecap help - by morzh - 03-12-2015, 02:55 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 03:11 PM
RE: Ecap help - by radiohenry - 03-12-2015, 03:47 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 05:50 PM
RE: Ecap help - by radiohenry - 03-12-2015, 07:12 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 08:33 PM
RE: Ecap help - by OldRestorer - 03-12-2015, 10:23 PM
RE: Ecap help - by radiohenry - 03-14-2015, 08:12 AM
RE: Ecap help - by OldRestorer - 03-14-2015, 11:45 AM
RE: Ecap help - by morzh - 03-14-2015, 11:59 AM
RE: Ecap help - by OldRestorer - 03-14-2015, 12:14 PM
RE: Ecap help - by radiohenry - 03-14-2015, 12:32 PM
RE: Ecap help - by morzh - 03-14-2015, 03:19 PM
RE: Ecap help - by OldRestorer - 03-14-2015, 05:29 PM
RE: Ecap help - by morzh - 03-14-2015, 06:44 PM
RE: Ecap help - by OldRestorer - 03-14-2015, 09:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6160 online users. [Complete List]
» 1 Member(s) | 6159 Guest(s)
