60MB needs some love
Looks like the ground lug is right next to the mounting screw for the adjacent coil bracket. I would install another ground lug under the mounting screw and then wire the two lugs together. The self tapping screws usually make very good contact to the chassis.
Would not trust the ground through the rivet as the tube socket phenolic compresses, which along with the corrosion results in poor contact.
60MB needs some love - by klondike98 - 02-21-2015, 12:36 PM
RE: 60MB needs some love - by Ron Ramirez - 02-21-2015, 12:52 PM
RE: 60MB needs some love - by morzh - 02-21-2015, 01:12 PM
RE: 60MB needs some love - by klondike98 - 02-21-2015, 03:10 PM
RE: 60MB needs some love - by klondike98 - 03-10-2015, 07:14 PM
RE: 60MB needs some love - by Ron Ramirez - 03-10-2015, 10:02 PM
RE: 60MB needs some love - by klondike98 - 03-10-2015, 10:13 PM
RE: 60MB needs some love - by klondike98 - 03-11-2015, 10:13 AM
RE: 60MB needs some love - by George Kirk - 03-11-2015, 02:15 PM
RE: 60MB needs some love - by klondike98 - 03-11-2015, 02:23 PM
RE: 60MB needs some love - by klondike98 - 03-11-2015, 07:50 PM
RE: 60MB needs some love - by Mondial - 03-12-2015, 12:01 AM
RE: 60MB needs some love - by klondike98 - 03-12-2015, 01:51 PM
RE: 60MB needs some love - by klondike98 - 03-15-2015, 07:50 PM
RE: 60MB needs some love - by sam - 03-15-2015, 08:06 PM
RE: 60MB needs some love - by klondike98 - 03-15-2015, 08:19 PM
RE: 60MB needs some love - by klondike98 - 03-17-2015, 09:39 PM
RE: 60MB needs some love - by klondike98 - 03-19-2015, 10:04 PM
RE: 60MB needs some love - by Mondial - 03-19-2015, 10:58 PM
RE: 60MB needs some love - by klondike98 - 03-20-2015, 11:43 AM
RE: 60MB needs some love - by Ron Ramirez - 03-20-2015, 12:05 PM
RE: 60MB needs some love - by klondike98 - 03-20-2015, 12:08 PM
RE: 60MB needs some love - by klondike98 - 03-20-2015, 07:47 PM
RE: 60MB needs some love - by Radioroslyn - 03-20-2015, 07:56 PM
RE: 60MB needs some love - by sam - 03-21-2015, 05:32 PM
Users browsing this thread: 16 Guest(s)
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3522 online users. [Complete List]
» 2 Member(s) | 3520 Guest(s)
