Safety Caps For Bakelite Block
Thank you everyone. I am going to go ahead and more the switch in front of the caps. Bill's idea of putting in a fuse sounds good to. I have to agree with Planigan, when I was younger all we had was a radio to listen too (late 1940's and early 1950's) and I don't remember having to plug it in before we turned it on Icon_razz. I hope this one will work because I did a total rewire and changed all the risistors and caps. Some of the resistors where creaked. Got a little work left, but I am sure I'll be asking for more help.
Bob
Safety Caps For Bakelite Block - by Bob - 01-08-2009, 10:38 PM
Re: Safety Caps For Bakelite Block - by codefox1 - 01-08-2009, 10:52 PM
Re: Safety Caps For Bakelite Block - by Bob - 01-08-2009, 11:00 PM
Re: Safety Caps For Bakelite Block - by codefox1 - 01-08-2009, 11:17 PM
Re: Safety Caps For Bakelite Block - by exray - 01-08-2009, 11:59 PM
Re: Safety Caps For Bakelite Block - by planigan - 01-09-2009, 12:25 AM
Re: Safety Caps For Bakelite Block - by Bob - 01-09-2009, 05:53 PM
Re: Safety Caps For Bakelite Block - by phly guy - 01-10-2009, 01:26 PM
Re: Safety Caps For Bakelite Block - by Bob - 01-10-2009, 09:53 PM
Re: Safety Caps For Bakelite Block - by phly guy - 01-12-2009, 10:56 AM
Re: Safety Caps For Bakelite Block - by Bob - 01-14-2009, 09:27 PM
Re: Safety Caps For Bakelite Block - by phly guy - 01-17-2009, 02:52 AM
There are currently 4465 online users. [Complete List]
» 1 Member(s) | 4464 Guest(s)
