UPDATE: Tubes tested. Canadian Philco Radio: ID and repair needed
Got a Mystery Part here..... component measures exactly 600R Which is my first clue that it's out of spec....
It was located at the highlighted location. This schematic is from a 41-95 but the component locations are exact in the amp section though different values. the 41-95 schematic lists this value as 680R 1/2W
this one's seen some heat.
RE: Update with Pics, New Canadian Philco Radio: ID and repair needed - by Ritchie - 03-12-2015, 07:43 PM
There are currently 5962 online users. [Complete List]
» 1 Member(s) | 5961 Guest(s)
