Found today in the local Goodwill.
Great find Gary! Congrats! You could also add a rca input to the transmitter, use a "Y" male rca connector to attach a tape deck or CD player ( stereo L & R to mono) if you wished. Add a 10' pc of wire to antenna and broadcast on AM into all your radios. What freq were those LPAM xmitters pre- set for?, or it may even be adjustable freq? Good luck with your restoration!!
Re: Found today in the local Goodwill. - by Syl - 01-09-2009, 12:18 PM
Re: Found today in the local Goodwill. - by Texasrocker - 01-10-2009, 12:03 AM
Found today in the local Goodwill 2 - by DeckApe - 01-10-2009, 11:28 PM
Re: Found today in the local Goodwill. - by Syl - 01-11-2009, 06:16 PM
Re: Found today in the local Goodwill. - by Arran - 07-14-2009, 12:47 AM
