41-280 dial restring
(03-13-2015, 01:13 AM)Arran Wrote:  If the dial only travels about 1/3 of the way before binding that usually means that you don't have enough turns of dial cord wrapped around the drum on the tuning capacitor, if that's so then the dial will stop moving once you hit one of those knotches in the edge of the drum.
A big clue here! the stringing diagram appears to show NO loops around the tuning cap, just in one side and out the other ....
41-280 dial restring - by Pffester - 03-06-2015, 08:03 PM
RE: 41-280 dial restring - by klondike98 - 03-06-2015, 10:30 PM
RE: 41-280 dial restring - by Pffester - 03-07-2015, 07:25 AM
RE: 41-280 dial restring - by klondike98 - 03-07-2015, 09:28 AM
RE: 41-280 dial restring - by Raleigh - 03-12-2015, 03:44 PM
RE: 41-280 dial restring - by Arran - 03-13-2015, 01:13 AM
RE: 41-280 dial restring - by Pffester - 03-14-2015, 08:45 AM
RE: 41-280 dial restring - by Pffester - 03-14-2015, 08:48 AM
RE: 41-280 dial restring - by Pffester - 03-14-2015, 11:29 AM
RE: 41-280 dial restring - by Pffester - 03-14-2015, 02:29 PM
