511 Issue
Thanks again guys....the output transformer is in and it actually sounds better than my philco 90 or 111 with a 15 ft antenna....original speaker too!
511 Issue - by bdi1976 - 02-28-2015, 09:26 AM
RE: 511 Issue - by morzh - 02-28-2015, 02:11 PM
RE: 511 Issue - by bdi1976 - 03-02-2015, 12:27 AM
RE: 511 Issue - by morzh - 03-02-2015, 09:38 AM
RE: 511 Issue - by Radioroslyn - 03-02-2015, 06:27 PM
RE: 511 Issue - by bdi1976 - 03-02-2015, 09:21 PM
RE: 511 Issue - by bdi1976 - 03-14-2015, 12:41 PM
RE: 511 Issue - by morzh - 03-14-2015, 12:53 PM
RE: 511 Issue - by Radioroslyn - 03-14-2015, 05:02 PM
RE: 511 Issue - by bdi1976 - 03-14-2015, 05:22 PM
