What year, make and model do I have??
Here's what it should look like:
[Image: http://www.philcoradio.com/gallery/image...42380x.jpg]
(Photo credit: David Kasabo)
What year, make and model do I have?? - by Guest - 12-22-2005, 02:36 PM
[No subject] - by Ron Ramirez - 12-22-2005, 02:39 PM
No idea how to post picture. - by Guest - 12-22-2005, 02:54 PM
[No subject] - by Ron Ramirez - 12-22-2005, 05:16 PM
[No subject] - by Ron Ramirez - 12-22-2005, 05:32 PM
faceplate - by Guest - 12-22-2005, 10:27 PM
[No subject] - by Ron Ramirez - 12-22-2005, 10:49 PM
Philco 91 Tuning Condenser
