610 help
Switch. Have you checked the switch?
There are very few weak links:
1. The Tube (checked)
2. The tube panel.
3. The coils.
4. The switch that commutates the coils.
Now, to check the switch you do not need to trace it: simply measure appopriate coils's continuities from the beginning of the circuit to the very end with the switch in a partiular position. If the switch is not closing properly you will see the open or large resistance where it should be a low coil's resistance.
610 help - by keith49vj3 - 03-07-2015, 11:54 AM
RE: 610 help - by morzh - 03-07-2015, 12:17 PM
RE: 610 help - by keith49vj3 - 03-07-2015, 12:26 PM
RE: 610 help - by morzh - 03-07-2015, 12:34 PM
RE: 610 help - by Ron Ramirez - 03-07-2015, 12:39 PM
RE: 610 help - by keith49vj3 - 03-08-2015, 05:48 PM
RE: 610 help - by Ron Ramirez - 03-08-2015, 06:36 PM
RE: 610 help - by keith49vj3 - 03-08-2015, 07:45 PM
RE: 610 help - by morzh - 03-08-2015, 07:54 PM
RE: 610 help - by keith49vj3 - 03-08-2015, 08:44 PM
RE: 610 help - by morzh - 03-08-2015, 08:59 PM
RE: 610 help - by keith49vj3 - 03-09-2015, 06:08 AM
RE: 610 help - by morzh - 03-09-2015, 09:28 AM
RE: 610 help - by klondike98 - 03-09-2015, 09:52 AM
RE: 610 help - by Eliot Ness - 03-10-2015, 08:18 AM
RE: 610 help - by Mondial - 03-10-2015, 09:37 AM
RE: 610 help - by keith49vj3 - 03-12-2015, 06:31 AM
RE: 610 help - by morzh - 03-12-2015, 08:11 AM
RE: 610 help - by keith49vj3 - 03-13-2015, 06:26 AM
RE: 610 help - by Mondial - 03-13-2015, 07:41 AM
RE: 610 help - by keith49vj3 - 03-13-2015, 10:15 PM
RE: 610 help - by Mondial - 03-14-2015, 08:01 AM
RE: 610 help - by keith49vj3 - 03-14-2015, 03:05 PM
RE: 610 help - by Radioroslyn - 03-14-2015, 04:52 PM
RE: 610 help - by keith49vj3 - 03-14-2015, 06:09 PM
RE: 610 help - by Mondial - 03-14-2015, 06:21 PM
RE: 610 help - by morzh - 03-14-2015, 06:34 PM
RE: 610 help - by keith49vj3 - 03-14-2015, 07:09 PM
RE: 610 help - by Mondial - 03-14-2015, 07:23 PM
RE: 610 help - by Radioroslyn - 03-14-2015, 07:25 PM
RE: 610 help - by keith49vj3 - 03-14-2015, 07:59 PM
RE: 610 help - by Radioroslyn - 03-14-2015, 08:18 PM
RE: 610 help - by klondike98 - 03-14-2015, 09:10 PM
RE: 610 help - by Ron Ramirez - 03-14-2015, 10:13 PM
