Philco 38-690 electrolytic capacitors--UPDATE
#32
Here are the part numbers, uf value and voltage ratings for the electrolytics on my 38-690 (Code 125).
Part 110: 2uf 450v; 2uf 450v, 1uf 450v, 10uf 50v, 2uf 300v.
Part 164: 3uf 475v; 2uf 300v; 8uf 475v.
Part 169: 8uf 475v; 10uf 50v
Part 170: 8uf 475v
Part 173: 18uf 500v
Part 176: 8uf 475v
Part 177: 8uf 500v
RE: Philco 38-690 electrolytic capacitors--UPDATE - by Diverted - 03-15-2015, 12:26 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2784 online users. [Complete List]
» 2 Member(s) | 2782 Guest(s)
