40-145 speaker issue
Is the rect tube wired different? 5Y4 and 7Y4 are not the same. Also, they have different filament voltage (5V and 6.3V respectively).
40-145 speaker issue - by OldRestorer - 03-12-2015, 10:17 PM
RE: 40-145 speaker issue - by sam - 03-13-2015, 04:06 AM
RE: 40-145 speaker issue - by Radioroslyn - 03-13-2015, 06:39 AM
RE: 40-145 speaker issue - by OldRestorer - 03-13-2015, 09:34 AM
RE: 40-145 speaker issue - by sam - 03-13-2015, 11:44 AM
RE: 40-145 speaker issue - by morzh - 03-13-2015, 11:50 AM
RE: 40-145 speaker issue - by OldRestorer - 03-13-2015, 12:03 PM
RE: 40-145 speaker issue - by sam - 03-13-2015, 12:11 PM
RE: 40-145 speaker issue - by morzh - 03-13-2015, 01:40 PM
RE: 40-145 speaker issue - by Radioroslyn - 03-13-2015, 05:00 PM
RE: 40-145 speaker issue - by OldRestorer - 03-16-2015, 04:47 PM
RE: 40-145 speaker issue - by Radioroslyn - 03-17-2015, 07:19 AM
RE: 40-145 speaker issue - by OldRestorer - 03-17-2015, 09:46 AM
RE: 40-145 speaker issue - by OldRestorer - 03-17-2015, 10:45 AM
RE: 40-145 speaker issue - by morzh - 03-17-2015, 10:51 AM
RE: 40-145 speaker issue - by OldRestorer - 03-17-2015, 10:51 AM
RE: 40-145 speaker issue - by Radioroslyn - 03-17-2015, 03:05 PM
RE: 40-145 speaker issue - by OldRestorer - 08-19-2015, 05:44 PM
RE: 40-145 speaker issue - by OldRestorer - 08-20-2015, 09:44 AM
RE: 40-145 speaker issue - by sam - 08-20-2015, 11:43 AM
RE: 40-145 speaker issue - by Raleigh - 08-20-2015, 02:39 PM
RE: 40-145 speaker issue - by OldRestorer - 08-20-2015, 02:50 PM
RE: 40-145 speaker issue - by Raleigh - 08-20-2015, 03:27 PM
RE: 40-145 speaker issue - by sam - 08-20-2015, 07:20 PM
RE: 40-145 speaker issue - by OldRestorer - 08-21-2015, 01:46 AM
RE: 40-145 speaker issue - by sam - 08-21-2015, 02:52 AM
RE: 40-145 speaker issue - by Raleigh - 08-21-2015, 04:09 PM
RE: 40-145 speaker issue - by OldRestorer - 08-22-2015, 05:33 PM
RE: 40-145 speaker issue - by sam - 08-24-2015, 01:47 PM
There are currently 6855 online users. [Complete List]
» 2 Member(s) | 6853 Guest(s)
