philco portabble ac/dc 42-842
terry
p1 of the 1st 1LE3- to p8 of the 1LB4+  nope both at .0
switch bad ?
switch pin out voltages
1) .069   5) .069   9) .067
2) .043   6) .043   10) .720
3) .0       7) .0      11) .705
4) 121v   8 ] 121v   12) not used
thanks sam
philco portabble ac/dc 42-842 - by sam - 03-15-2015, 11:16 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-16-2015, 01:29 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-17-2015, 12:24 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-17-2015, 02:38 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-20-2015, 03:55 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-20-2015, 04:50 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-25-2015, 04:32 AM
RE: philco portabble ac/dc 42-842 - by morzh - 03-25-2015, 11:07 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-25-2015, 11:33 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-28-2015, 08:50 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-08-2015, 07:06 PM
RE: philco portabble ac/dc 42-842 - by morzh - 04-08-2015, 08:04 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-08-2015, 10:38 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-09-2015, 07:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
