philco portabble ac/dc 42-842
terry
dcv on pins 1 and 2. Pin 1 should have about 100v pin 2  should be at 9v
pin1) is 72.5dcv
pin2) is 10.9dcv
thanks sam
philco portabble ac/dc 42-842 - by sam - 03-15-2015, 11:16 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-16-2015, 01:29 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-17-2015, 12:24 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-17-2015, 02:38 PM
RE: philco portabble ac/dc 42-842 - by sam - 03-20-2015, 03:55 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-20-2015, 04:50 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-25-2015, 04:32 AM
RE: philco portabble ac/dc 42-842 - by morzh - 03-25-2015, 11:07 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-25-2015, 11:33 AM
RE: philco portabble ac/dc 42-842 - by sam - 03-28-2015, 08:50 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-08-2015, 07:06 PM
RE: philco portabble ac/dc 42-842 - by morzh - 04-08-2015, 08:04 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-08-2015, 10:38 PM
RE: philco portabble ac/dc 42-842 - by sam - 04-09-2015, 07:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
