38-116 short wave disabled during WW2
This was all covered by the umbrella Executive Order 9066, wherein they started excluding Japanese immigrants from several "sensitive areas", and moved on to confiscating property, disabling radios, relocation and internment.
RE: 38-116 short wave disabled during WW2 - by BrendaAnnD - 03-18-2015, 09:38 PM
