Found and Now Restored Model 70
Hi Mike,
That's a nice old radio you have there. It's a hard radio for most beginners to tackle. Take your time and visit philcorepairbench.com on how to rebuild the bakelite blocks. The cap on the side of the bakelite block is likely a vintage repair. Common sight on radios of this vintage.
Richard
Found and Now Restored Model 70 - by mikehorning - 01-12-2009, 08:06 AM
Re: Found a Model 70 - by rghines1 - 01-12-2009, 11:10 AM
Re: Found a Model 70 - by Uffda - 01-12-2009, 09:27 PM
Re: Found a Model 70 - by mikehorning - 01-13-2009, 06:57 PM
Re: Found a Model 70 - by gary rabbitt - 01-13-2009, 10:17 PM
Re: Found a Model 70 - by mikehorning - 02-22-2009, 09:58 AM
Re: Found and Now Restored Model 70 - by Arran - 02-22-2009, 11:25 PM
Re: Found and Now Restored Model 70 - by Arran - 02-25-2009, 01:33 AM
Philco 91 Tuning Condenser
There are currently 8097 online users. [Complete List]
» 2 Member(s) | 8095 Guest(s)
