37-650 Simple Questions
Ok, here's a couple simple ones:
First, regarding the dial lamp- should the "reflector" cup the bulb sits in be shiny inside, or black painted, as mine is now?
Second, what does the "Shadow Meter" actually do, and how does it do this? It appears to be an empty tube with a coil around it that a lamp shines through.
Thanks!
Scott
PS-
Ron- Bought your book from Radio Daze today... Said they were getting low on stock, and I felt I better oughta... Can't wait to see/read it, so I can be a more fully informed Philcophile. S.
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
37-650 Simple Questions - by Robbie Roberts - 12-22-2005, 06:29 PM
[No subject] - by Ron Ramirez - 12-22-2005, 08:29 PM
Update on 37-650 Project - by Robbie Roberts - 01-03-2006, 03:07 AM
[No subject] - by Terry Burns - 01-03-2006, 07:55 AM
DMM? - by Robbie Roberts - 01-03-2006, 09:16 AM
[No subject] - by Chuck Schwark - 01-03-2006, 09:58 AM
[No subject] - by Robbie Roberts - 01-03-2006, 12:59 PM
ITS ALIVE!!! - by Robbie Roberts - 01-04-2006, 01:05 AM
Seems OK- restoration report - by Robbie Roberts - 01-04-2006, 03:21 AM
