"Radiorgan" Dilemna
Hey Ed,
Thanks for the info. I've got a bottle of super glue with the applicator you mention and will put it to good use! Funny you mention the needle-nose pliers, I tried doing exactly your suggestion on my first attempt and one tiny tab end snapped off. Didn't hurt anything, but scared me away from going further. I'll get it done now, just didn't even know before if I had to take the phenolic board off or if there was a "trick" I wasn't aware of... I appreciate your help!
Joe
"Ignorance is bliss...'til you have to fix a radio..."
"Radiorgan" Dilemna - by jayoungs - 12-29-2008, 12:07 PM
Re: "Radiorgan" Dilemna - by etech - 12-30-2008, 10:16 AM
Re: "Radiorgan" Dilemna - by jayoungs - 12-30-2008, 11:52 AM
Re: "Radiorgan" Dilemna - by jayoungs - 01-12-2009, 01:02 PM
Re: "Radiorgan" Dilemna - by etech - 01-12-2009, 04:43 PM
Re: "Radiorgan" Dilemna - by jayoungs - 01-12-2009, 05:29 PM
Re: "Radiorgan" Dilemna - by jayoungs - 01-13-2009, 12:17 PM
Re: "Radiorgan" Dilemna - by etech - 01-13-2009, 02:28 PM
Re: "Radiorgan" Dilemna - by jayoungs - 01-13-2009, 05:06 PM
Re: "Radiorgan" Dilemna - by etech - 01-14-2009, 11:05 AM
Eico 232 VTVM Schematic
There are currently 9017 online users. [Complete List]
» 1 Member(s) | 9016 Guest(s)
