Resistor values question
#35
Is it ok to use. 450 volt 8 mfd I. Place of a 500v?
I am working on a halson 50R and the 50x has the same tube lineup.
http://www.nostalgiaair.org/PagesByModel...008951.pdf
I am replacing the ecaps and there is that infamous box cap. It says 8 on it. But under it the positives are cut. Could this 8 @ 500 be the replacement?
Here are some pics
Kirk
Resistor values question - by OldRestorer - 03-05-2015, 01:29 PM
RE: Resistor values question - by morzh - 03-05-2015, 01:41 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 02:02 PM
RE: Resistor values question - by Kestas - 03-05-2015, 02:22 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 03:05 PM
RE: Resistor values question - by sam - 03-05-2015, 03:22 PM
RE: Resistor values question - by morzh - 03-05-2015, 04:25 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 05:02 PM
RE: Resistor values question - by sam - 03-05-2015, 05:13 PM
RE: Resistor values question - by morzh - 03-05-2015, 05:16 PM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:39 AM
RE: Resistor values question - by morzh - 03-06-2015, 10:44 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:53 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:58 AM
RE: Resistor values question - by sam - 03-06-2015, 11:10 AM
RE: Resistor values question - by morzh - 03-06-2015, 11:12 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 01:24 PM
RE: Resistor values question - by Radioroslyn - 03-06-2015, 02:34 PM
RE: Resistor values question - by Radioroslyn - 03-06-2015, 03:09 PM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:08 PM
RE: Resistor values question - by OldRestorer - 03-09-2015, 12:01 PM
RE: Resistor values question - by morzh - 03-09-2015, 12:47 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 10:03 AM
RE: Resistor values question - by Kestas - 03-19-2015, 11:41 AM
RE: Resistor values question - by OldRestorer - 03-19-2015, 01:10 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 02:55 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 04:08 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 05:40 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 06:06 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 07:40 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 07:45 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 08:02 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 09:54 PM
RE: Resistor values question - by Mondial - 03-19-2015, 11:09 PM
RE: Resistor values question - by OldRestorer - 03-20-2015, 12:59 PM
RE: Resistor values question - by OldRestorer - 03-20-2015, 01:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
