Bakelight block rebuilding advice requested
Paul, axial caps actually are easier to install but radial will work. I prefer axial caps as they fit easier and never found the need to sleeve them.
Jerry
RE: Bakelight block rebuilding advice requested - by jerryhawthorne - 03-20-2015, 04:26 PM
There are currently 5627 online users. [Complete List]
» 1 Member(s) | 5626 Guest(s)
