Loop antenna vs long wire
Thanks David,  Found the Book in PDF format and downloaded it. Now to get the time and read it.
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Loop antenna vs long wire - by 462ron - 03-20-2015, 09:22 PM
RE: Loop antenna vs long wire - by Phlogiston - 03-20-2015, 11:48 PM
RE: Loop antenna vs long wire - by 462ron - 03-21-2015, 10:00 PM
RE: Loop antenna vs long wire - by Ron Ramirez - 03-21-2015, 10:39 PM
RE: Loop antenna vs long wire - by 462ron - 03-22-2015, 12:07 PM
RE: Loop antenna vs long wire - by David - 03-22-2015, 12:50 PM
RE: Loop antenna vs long wire - by 462ron - 03-22-2015, 07:22 PM
RE: Loop antenna vs long wire - by Alan Douglas - 03-23-2015, 05:24 PM
RE: Loop antenna vs long wire - by Mondial - 03-23-2015, 09:34 PM
RE: Loop antenna vs long wire - by 462ron - 03-24-2015, 07:21 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
