Loop antenna vs long wire
A shielded loop can be insensitive to electrostatic fields (local RFI), but an unshielded one acts like a short vertical antenna.
The other useful property of a loop is nulling a signal broadside to it (the signal generates equal voltages in the two vertical sides of the loop, which cancel out). Balancing the feed well enough to achieve this is tricky however.
Loop antenna vs long wire - by 462ron - 03-20-2015, 09:22 PM
RE: Loop antenna vs long wire - by Phlogiston - 03-20-2015, 11:48 PM
RE: Loop antenna vs long wire - by 462ron - 03-21-2015, 10:00 PM
RE: Loop antenna vs long wire - by Ron Ramirez - 03-21-2015, 10:39 PM
RE: Loop antenna vs long wire - by 462ron - 03-22-2015, 12:07 PM
RE: Loop antenna vs long wire - by David - 03-22-2015, 12:50 PM
RE: Loop antenna vs long wire - by 462ron - 03-22-2015, 07:22 PM
RE: Loop antenna vs long wire - by Alan Douglas - 03-23-2015, 05:24 PM
RE: Loop antenna vs long wire - by Mondial - 03-23-2015, 09:34 PM
RE: Loop antenna vs long wire - by 462ron - 03-24-2015, 07:21 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
