Philco 49-1075 Non-working turntable
If you can post a picture of the phonograph it would help, and if you kow what phonograph it is. Did you check to see if thee is voltage going to the motor? If there is you may need a new motor. Also, make sure there isnt any binding from it to the platter.
Philco 49-1075 Non-working turntable - by dennis491075 - 03-23-2015, 07:32 PM
RE: Philco 49-1075 Non-working turntable - by Warren - 03-23-2015, 10:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
