Shock Mounting for 41-280 et al
Excellent ideas and thank you! The website that mandh posted is an excellent resource that I didn't know about.
I can't seem to find the shock mounts in the picture below, though. I went and checked some hardware outlets like Texasrocker recommends and I found metal washers with integral rubber mounted to them that I think will work for one of those washer styles. I also found plain neoprene washers that I could probably stack to get the right thickness for the other washer shown. I'm not trying to get letter perfect with this one in terms of authenticity, but I would like to try and maintain factory spacing and dimensions.
Any other ideas where I might be able to find these?
[Image: http://i92.photobucket.com/albums/l23/jh...2Mount.jpg]
Shock Mounting for 41-280 et al - by Guest - 01-12-2009, 06:37 PM
Re: Shock Mounting for 41-280 et al - by mandh - 01-12-2009, 07:20 PM
Re: Shock Mounting for 41-280 et al - by Guest - 01-13-2009, 06:30 PM
Re: Shock Mounting for 41-280 et al - by planigan - 01-14-2009, 02:08 PM
Re: Shock Mounting for 41-280 et al - by Sean - 01-14-2009, 02:26 PM
There are currently 9922 online users. [Complete List]
» 3 Member(s) | 9919 Guest(s)
