"Mucked up" Philco 41-231
Yep, one of those 40-s philcos, rubber wiring etc.....
Q: What do you get when you mix rubber and Candohm in one place?
Icon_lol Icon_mrgreen
Well, now that Alabma HRS taught you (they have some good folks there, like Dee Haynes ) hopefully well, you could clean that mess up.
Keep in mind, though it is not true hot chassis, it is still not a transformer radio so can whack you when least expected. Do not work on it in wet basements, next to grounded devices and ONLY work on it using isolation transformer, ESPECIALLY if you need to perform alignment.
Now go put that smoke back where it belongs.
"Mucked up" Philco 41-231 - by TheUniversalDave1 - 03-24-2015, 09:37 PM
RE: "Mucked up" Philco 41-231 - by Warren - 03-24-2015, 10:10 PM
RE: "Mucked up" Philco 41-231 - by morzh - 03-24-2015, 10:17 PM
RE: "Mucked up" Philco 41-231 - by Radioroslyn - 03-24-2015, 10:27 PM
RE: "Mucked up" Philco 41-231 - by klondike98 - 03-24-2015, 10:47 PM
RE: "Mucked up" Philco 41-231 - by morzh - 03-24-2015, 10:55 PM
RE: "Mucked up" Philco 41-231 - by sam - 03-24-2015, 11:45 PM
RE: "Mucked up" Philco 41-231 - by Radioroslyn - 03-25-2015, 07:10 AM
RE: "Mucked up" Philco 41-231 - by Radioroslyn - 03-25-2015, 08:49 PM
RE: "Mucked up" Philco 41-231 - by klondike98 - 03-26-2015, 08:14 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
