Is the 38-12 the same cabinet as the PT-30???
This is what I picked up.
http://www.radioattic.com/item.htm?radio=1000243
And this is the back I found.
http://www.ebay.com/itm/Reproduction-Rad...5ad50db57e
Cheers!
John
RE: Is the 38-12 the same cabinet as the PT-30??? - by jtieri - 03-24-2015, 11:11 PM
