Found today in the local Goodwill.
Hi Guys,
Thanks Syl for the diagram of the little amp. I have never worked with those surface mount things but should be no problem. Looks very good and when encased you'd barely see it. I assume the transistor is any small signal NPN type? I have some of those, but they are not surface mount, they should work.
I think however, I may try and rebuild the original. I will need to read your tutorial again for specifics. Whether to remove the element from another cart, or try to get a crystal bar element would be the only decision. I may have a newer cart around here I wil have to check. I had bought some stuff from a closing electronics store, and I think there were some cartridges in the stuff. Opening the cart would not be a problem, so I may give it a try, why not?
The main goal on this player is to get it to play as is should. Not worried about adding another input as I think the range of these is not that great.
As for the coupling to the AC line, I can't see where it shows that in the diagram. The antenna symbol is all that's shown on the diagram. I know the carpet tacks and the wire inside this one does not look original.
Take care, and I will get back to to you on what I find.
Gary.
Re: Found today in the local Goodwill. - by Syl - 01-09-2009, 12:18 PM
Found today in the local Goodwill 2 - by DeckApe - 01-10-2009, 11:28 PM
Re: Found today in the local Goodwill. - by Syl - 01-11-2009, 06:16 PM
Re: Found today in the local Goodwill. - by gary rabbitt - 01-13-2009, 10:13 PM
Re: Found today in the local Goodwill. - by Arran - 07-14-2009, 12:47 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5571 online users. [Complete List]
» 2 Member(s) | 5569 Guest(s)
