Philco Model 20 escessive hum
I thought I was being smart and put a 10mf @450v ecaps in my 20 but it made the bleeder/bias resistor get really HOT. As Modial sez replace the 10mf s with mylars of the proper values as per the schematic. The ecaps cannot take the ripple current .Sooner or later they will short.
Philco Model 20 escessive hum - by Tubesforme - 03-25-2015, 04:52 PM
RE: Philco Model 20 escessive hum - by klondike98 - 03-25-2015, 05:17 PM
RE: Philco Model 20 escessive hum - by Mondial - 03-25-2015, 05:34 PM
RE: Philco Model 20 escessive hum - by Warren - 03-25-2015, 07:00 PM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-25-2015, 07:15 PM
RE: Philco Model 20 escessive hum - by Warren - 03-25-2015, 07:24 PM
RE: Philco Model 20 escessive hum - by Mondial - 03-25-2015, 08:02 PM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-25-2015, 10:09 PM
RE: Philco Model 20 escessive hum - by Radioroslyn - 03-25-2015, 08:47 PM
RE: Philco Model 20 escessive hum - by Arran - 03-27-2015, 01:01 AM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-30-2015, 01:11 PM
RE: Philco Model 20 escessive hum - by morzh - 03-27-2015, 09:52 AM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-27-2015, 04:25 PM
RE: Philco Model 20 escessive hum - by Mondial - 03-27-2015, 04:36 PM
RE: Philco Model 20 escessive hum - by morzh - 03-27-2015, 04:51 PM
RE: Philco Model 20 escessive hum - by radiohenry - 03-28-2015, 09:16 AM
RE: Philco Model 20 escessive hum - by morzh - 03-28-2015, 10:02 AM
RE: Philco Model 20 escessive hum - by radiohenry - 03-28-2015, 04:35 PM
RE: Philco Model 20 escessive hum - by klondike98 - 03-28-2015, 08:47 PM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-30-2015, 01:17 PM
RE: Philco Model 20 escessive hum - by radiohenry - 03-28-2015, 10:17 PM
RE: Philco Model 20 escessive hum - by morzh - 03-30-2015, 01:27 PM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-30-2015, 01:37 PM
RE: Philco Model 20 escessive hum - by morzh - 03-30-2015, 01:41 PM
RE: Philco Model 20 escessive hum - by morzh - 03-30-2015, 01:48 PM
RE: Philco Model 20 escessive hum - by codefox1 - 03-30-2015, 03:21 PM
RE: Philco Model 20 escessive hum - by Tubesforme - 03-31-2015, 03:14 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
