Philco Tropic (UK) B.2810 Restoration
Hi welcome to the forum! This website is the best. Everyone is helpful and a lot of fun to talk to. I hope you find it helpful and again welcome.
RE: Seeking information on this radio - by PhilcoJohn - 03-26-2015, 06:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
