Philco Tropic (UK) B.2810 Restoration
Welcome to the Phorum!! Yes, please post your restoration progress. We don't see too many UK sets here.
RE: Seeking information on this radio - by klondike98 - 03-26-2015, 07:08 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
