Dial on 116 to dark no light getting thru
  To make this 116 tombstone that i'm restoring  as nice as can be I think I should get a new dial reason being is that light from bulb is barely seen though the dial pointer hole that's on the plastic band switch plate. The lettering is good on dial but cant clean that side because it will remove the lettering, cleaning back side did not do any good. I want the light to show thru the dial so you can see the little arrow pointer. Any cures to salvage dial or bite the bullet and get new dial?
Dial on 116 to dark no light getting thru - by Fred Taylor - 03-26-2015, 09:25 PM
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1640 online users. [Complete List]
» 1 Member(s) | 1639 Guest(s)
