Mershon copper capacitors
I've seen one or two of the Spragues - the ones that passed through here were nickel plated over copper. I only know that because some of the nickel had worn, revealing the copper underneath.
Mershon copper capacitors - by albertgen - 03-24-2015, 06:19 PM
RE: Mershon copper capacitors - by morzh - 03-24-2015, 06:23 PM
RE: Mershon copper capacitors - by albertgen - 03-24-2015, 07:46 PM
RE: Mershon copper capacitors - by klondike98 - 03-24-2015, 10:52 PM
RE: Mershon copper capacitors - by Arran - 03-27-2015, 01:24 AM
RE: Mershon copper capacitors - by Ron Ramirez - 03-27-2015, 08:05 AM
RE: Mershon copper capacitors - by morzh - 03-27-2015, 08:57 AM
RE: Mershon copper capacitors - by Arran - 03-27-2015, 09:47 PM
RE: Mershon copper capacitors - by Alan Douglas - 03-28-2015, 07:15 PM
RE: Mershon copper capacitors - by Arran - 03-29-2015, 03:36 AM
RE: Mershon copper capacitors - by morzh - 03-29-2015, 08:50 AM
RE: Mershon copper capacitors - by mikethedruid - 03-29-2015, 02:38 PM
RE: Mershon copper capacitors - by morzh - 03-29-2015, 03:41 PM
RE: Mershon copper capacitors - by Arran - 03-29-2015, 11:41 PM
RE: Mershon copper capacitors - by Ron Ramirez - 03-30-2015, 06:36 AM
RE: Mershon copper capacitors - by Arran - 03-31-2015, 12:49 AM
RE: Mershon copper capacitors - by morzh - 03-30-2015, 10:35 AM
RE: Mershon copper capacitors - by Alan Douglas - 03-31-2015, 06:04 PM
RE: Mershon copper capacitors - by ntsc525 - 07-15-2017, 10:31 PM
The speaker table error?
Philco 70 antenna lead
