Dial on 116 to dark no light getting thru
Here's the one I use for 1936-38 Philcos with the bulb mounted behind the dial and pointing at it:
http://www.pinballlife.com/index.php?p=product&id=2561
I had mentioned in another thread that I had a 37-690 with a darkened dial scale, and the original #55 was barely getting the job done. The LED in the link above helped a great deal. Icon_thumbup The lamp Mondial linked to would also be a good choice.
Terry, what is "oms"? Mineral spirits? Yes, you can clean those printed phenolic dials with mineral spirits. Just don't get aggressive or use a lot of pressure, or else even mineral spirits will cause the numbers to fade. Never use water, ammonia, or Windex-type cleaners on these dial scales!
RE: Dial on 116 to dark no light getting thru - by Ron Ramirez - 03-27-2015, 08:13 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
