What exactly are these?
Some info on the "Socket Power"
http://philcoradio.com/phorum/showthread...t+power%22
http://philcoradio.com/phorum/showthread...96#pid7196
You can get schematic from Chuck.
What exactly are these? - by OldRestorer - 03-27-2015, 09:53 PM
RE: What exactly are these? - by morzh - 03-27-2015, 09:56 PM
RE: What exactly are these? - by klondike98 - 03-27-2015, 10:06 PM
RE: What exactly are these? - by Ron Ramirez - 03-27-2015, 10:07 PM
RE: What exactly are these? - by Radioroslyn - 03-27-2015, 10:47 PM
RE: What exactly are these? - by Jayce - 03-27-2015, 11:10 PM
RE: What exactly are these? - by OldRestorer - 03-28-2015, 07:56 AM
RE: What exactly are these? - by morzh - 03-28-2015, 09:59 AM
RE: What exactly are these? - by Chuck Schwark - 04-10-2015, 09:14 AM
RE: What exactly are these? - by Ron Ramirez - 04-10-2015, 03:17 PM
RE: What exactly are these? - by Radioroslyn - 03-28-2015, 08:51 PM
RE: What exactly are these? - by Jayce - 03-28-2015, 08:56 PM
RE: What exactly are these? - by David - 03-29-2015, 02:11 PM
RE: What exactly are these? - by exray - 04-10-2015, 06:31 AM
RE: What exactly are these? - by Marsupial - 04-10-2015, 01:52 PM
RE: What exactly are these? - by OldRestorer - 04-10-2015, 03:31 PM
