Magic Loop Antenna Idea - Advice?
if you want a really cheap alternative i use slinkies,you can hang them from a hook on the ceiling,pushpin in the wall or string them out on the floor along a wall,they work very well.
phil
Magic Loop Antenna Idea - Advice? - by jayoungs - 01-12-2009, 10:01 AM
Re: Magic Loop Antenna Idea - Advice? - by exray - 01-12-2009, 07:23 PM
Re: Magic Loop Antenna Idea - Advice? - by philco phan - 01-14-2009, 12:52 PM
Eico 232 VTVM Schematic
There are currently 9261 online users. [Complete List]
» 2 Member(s) | 9259 Guest(s)
