116b band swicth nob?
(03-27-2015, 09:20 PM)Ron Ramirez Wrote:  I have also seen both the round black knob as well as the oddball bandswitch knob that was only used in the 1936 season (which Terry linked to above) on the early (shouldered) 116B, so I would say either one is OK.
THANKS FOR QUICK REPLY Icon_crazy
116b band swicth nob? - by Fred Taylor - 03-27-2015, 07:48 PM
RE: 116b band swicth nob? - by Radioroslyn - 03-27-2015, 08:25 PM
RE: 116b band swicth nob? - by Ron Ramirez - 03-27-2015, 09:20 PM
RE: 116b band swicth nob? - by Fred Taylor - 03-27-2015, 11:06 PM
There are currently 6912 online users. [Complete List]
» 2 Member(s) | 6910 Guest(s)
