Shock Mounting for 41-280 et al
Will a standard rubber grommet not work as a replacement for the grommet in the photo? I know the big box home improvement stores have rubber grommets in drawers in the hardware section and many local hardware stores have an even larger selection. The metal eyelet that appears to be present in the original can be removed, cleaned up and re-used with the new grommet. That's what I always do anyway.
Sean
WØKPX
Shock Mounting for 41-280 et al - by Guest - 01-12-2009, 06:37 PM
Re: Shock Mounting for 41-280 et al - by mandh - 01-12-2009, 07:20 PM
Re: Shock Mounting for 41-280 et al - by Guest - 01-13-2009, 06:30 PM
Re: Shock Mounting for 41-280 et al - by planigan - 01-14-2009, 02:08 PM
Re: Shock Mounting for 41-280 et al - by Sean - 01-14-2009, 02:26 PM
There are currently 11342 online users. [Complete List]
» 2 Member(s) | 11340 Guest(s)
