Mershon copper capacitors
Mershon had most of the patents (not all) but Amrad was the licensed manufacturer. That division was sold to Magnavox in Ft. Wayne. Presumably Magnavox licensed Sprague.
I'm not aware that Fessenden had anything to do with electric lamps after leaving Edison's employ in the 1880s.
Mershon copper capacitors - by albertgen - 03-24-2015, 06:19 PM
RE: Mershon copper capacitors - by morzh - 03-24-2015, 06:23 PM
RE: Mershon copper capacitors - by albertgen - 03-24-2015, 07:46 PM
RE: Mershon copper capacitors - by klondike98 - 03-24-2015, 10:52 PM
RE: Mershon copper capacitors - by Arran - 03-27-2015, 01:24 AM
RE: Mershon copper capacitors - by Ron Ramirez - 03-27-2015, 08:05 AM
RE: Mershon copper capacitors - by morzh - 03-27-2015, 08:57 AM
RE: Mershon copper capacitors - by Arran - 03-27-2015, 09:47 PM
RE: Mershon copper capacitors - by Alan Douglas - 03-28-2015, 07:15 PM
RE: Mershon copper capacitors - by Arran - 03-29-2015, 03:36 AM
RE: Mershon copper capacitors - by morzh - 03-29-2015, 08:50 AM
RE: Mershon copper capacitors - by mikethedruid - 03-29-2015, 02:38 PM
RE: Mershon copper capacitors - by morzh - 03-29-2015, 03:41 PM
RE: Mershon copper capacitors - by Arran - 03-29-2015, 11:41 PM
RE: Mershon copper capacitors - by Ron Ramirez - 03-30-2015, 06:36 AM
RE: Mershon copper capacitors - by Arran - 03-31-2015, 12:49 AM
RE: Mershon copper capacitors - by morzh - 03-30-2015, 10:35 AM
RE: Mershon copper capacitors - by Alan Douglas - 03-31-2015, 06:04 PM
RE: Mershon copper capacitors - by ntsc525 - 07-15-2017, 10:31 PM
91H Code 126 Restore
There are currently 3330 online users. [Complete List]
» 1 Member(s) | 3329 Guest(s)
