37-650 Vernier Fine Tuning Mechanism
All is made clear with re-building this vernier shaft assembly in my Service Tip #39.
It does show the 1938 version, but I believe they are the same assy. or very close
so you can use the info and diagram.
Here: http://philcorepairbench.com/tips/svctip39.htm
Chuck
RE: 37-650 Vernier Fine Tuning Mechanism - by Chuck Schwark - 03-29-2015, 10:57 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
