Help radio philco model 23A
Hello Allesandro. You may want to contact Dave at http://www.justradios.com in Canada. He has a extensive collection of schematics. If I had one, would be glad to share, sorry I dont have much on Canadian Model Philcos here. Perhaps others here may be able to help as well. Good luck with your Philco restoration!
Help radio philco model 23A - by Guest - 01-14-2009, 07:03 PM
Re: Help radio philco model 23A - by Texasrocker - 01-15-2009, 12:22 AM
Re: Help radio philco model 23A - by Guest - 01-19-2009, 01:47 PM
There are currently 10859 online users. [Complete List]
» 2 Member(s) | 10857 Guest(s)
