Push button switches on 40-190
Hello Bob. For the ball-bearings on the tuner section (variable capacitor), you can just spray a small amt of WD-40 into the bearings and the other frame points where the cap rotates, then rotate the tuner assy manually until it rotates freely and easily. Do this while set is unplugged & not operating. Remove the excess WD-40 overspray with clean paper towel or Q-tips. You should be good to go.
Push button switches on 40-190 - by Bob - 01-14-2009, 09:23 PM
Re: Push button switches on 40-190 - by Texasrocker - 01-15-2009, 12:44 AM
Re: Push button switches on 40-190 - by mandh - 01-15-2009, 08:42 AM
Re: Push button switches on 40-190 - by scooby214 - 01-15-2009, 03:29 PM
Re: Push button switches on 40-190 - by Bob - 01-15-2009, 06:27 PM
Re: Push button switches on 40-190 - by scooby214 - 01-15-2009, 10:37 PM
Re: Push button switches on 40-190 - by Bob - 01-17-2009, 12:06 PM
Re: Push button switches on 40-190 - by BDM - 01-18-2009, 12:07 PM
Re: Push button switches on 40-190 - by scooby214 - 01-21-2009, 10:17 PM
There are currently 4099 online users. [Complete List]
» 1 Member(s) | 4098 Guest(s)
