Philco 42-1012
If you want to check filaments you disconnect transformer, as in parallel the transformer wins and it is, as said before, only few tenths of ohm.
but I think you are OK, as you can check wiring separately without disconnecting, and the tubes should be checked anyway each on its own.
Philco 42-1012 - by vecher - 03-30-2015, 12:29 AM
RE: Philco 42-1012 - by klondike98 - 03-30-2015, 08:55 AM
RE: Philco 42-1012 - by morzh - 03-30-2015, 10:40 AM
RE: Philco 42-1012 - by davidff - 03-31-2015, 10:09 AM
RE: Philco 42-1012 - by vecher - 04-02-2015, 02:40 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
