The 39-116 project: the beginning
I may have found a transformer that will do the trick in my stash (didn't even remember having it.) It's a universal that seems to work pretty well, with the divider network on the feedback tap. Good sound, good power output. Still hope to find an original to put in there, though. Started changing the crumbly rubber wire on the surface (mainly to the lamp sockets.)
Now I need to find a bunch of the lamp sockets for the station indicators. I have posted this need in the WTB thread.
The 39-116 project: the beginning - by BrendaAnnD - 03-20-2015, 05:47 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 10:39 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 02:39 PM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 11:54 AM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 12:43 PM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:04 AM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:37 AM
RE: The 39-116 project: the beginning - by BrendaAnnD - 03-31-2015, 10:01 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:39 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:59 AM
RE: The 39-116 project: the beginning - by morzh - 04-16-2015, 05:11 PM
RE: The 39-116 project: the beginning - by murf - 04-19-2015, 05:49 PM
RE: The 39-116 project: the beginning - by Edisla - 10-24-2017, 03:55 PM
Users browsing this thread: 14 Guest(s)
The speaker table error?
Philco 70 antenna lead
