Philco 41-105
You should send it to Sam he loves replacing rubber wire!! Ha Ha
Some of those smaller chassis can be a real pita to work on. A friend
gave me a little PT-61 to get work and he told me that he had
recapped it. Thinking this would be a quick job I got it home had
a look at it What didn't tell me is that in doing so he had knocked
off about half of the rubber insulation. It's a kwel set but a pita none
the less.
http://philcoradio.com/gallery/1940b.htm#u
Gud Lk w/ your's
Philco 41-105 - by Jim Dutridge - 06-24-2014, 04:54 PM
RE: Philco 41-105 - by Arran - 06-25-2014, 02:38 AM
RE: Philco 41-105 - by Jim Dutridge - 06-25-2014, 09:13 AM
RE: Philco 41-105 - by jerryhawthorne - 06-25-2014, 01:08 PM
RE: Philco 41-105 - by TA Forbes - 06-25-2014, 01:28 PM
RE: Philco 41-105 - by Ron Ramirez - 06-26-2014, 05:55 PM
RE: Philco 41-105 - by Jim Dutridge - 03-30-2015, 05:38 PM
RE: Philco 41-105 - by Radioroslyn - 03-30-2015, 06:03 PM
RE: Philco 41-105 - by sam - 03-30-2015, 06:59 PM
RE: Philco 41-105 - by Radioroslyn - 03-30-2015, 07:43 PM
RE: Philco 41-105 - by sam - 03-31-2015, 03:52 AM
RE: Philco 41-105 - by Jim Dutridge - 03-31-2015, 04:50 PM
RE: Philco 41-105 - by Radioroslyn - 03-31-2015, 07:38 PM
RE: Philco 41-105 - by sam - 04-01-2015, 03:55 AM
RE: Philco 41-105 - by Ron Ramirez - 04-01-2015, 08:16 AM
