46-421 question
Hi Jim, There are several threads on these types of caps you can search out.  Chuck has a service tip on this as well. Some indicate you don't really need the little coil of wire as it was a way to suppress radio signals that are no longer a problem.  Most folks pull the old cap out of the tube, stuffing in a new cap and leaving the coil of wire in place (or replacing it after the cap is stuffed).  Here's a picture (a little out of focus) of one restuffed:
[Image: https://dl.dropboxusercontent.com/u/5462...22_cap.jpg]
46-421 question - by brownie45 - 04-01-2015, 08:45 AM
RE: 46-421 question - by klondike98 - 04-01-2015, 09:55 AM
RE: 46-421 question - by brownie45 - 04-01-2015, 10:02 AM
RE: 46-421 question - by Radioroslyn - 04-01-2015, 09:09 PM
RE: 46-421 question - by brownie45 - 04-02-2015, 07:50 AM
RE: 46-421 question - by klondike98 - 04-02-2015, 09:54 AM
RE: 46-421 question - by brownie45 - 04-02-2015, 05:53 PM
RE: 46-421 question - by Radioroslyn - 04-02-2015, 07:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
