50-925 no FM
Terry,
The rectifier has been replaced along with a 100 ohm 5W resistor in series. When I hook up my sig gen to the ant, it goes into V1 and doesn't come out. I replaced the tube with a known good one. Still nothing, not even static.
Eric
The Villages, FL
50-925 no FM - by Eric Adams - 03-31-2015, 10:28 PM
RE: 50-925 no FM - by Radioroslyn - 04-01-2015, 06:38 AM
RE: 50-925 no FM - by Eric Adams - 04-01-2015, 11:10 AM
RE: 50-925 no FM - by Radioroslyn - 04-01-2015, 09:01 PM
RE: 50-925 no FM - by David - 04-01-2015, 09:10 PM
RE: 50-925 no FM - by Eric Adams - 04-01-2015, 09:42 PM
RE: 50-925 no FM - by Radioroslyn - 04-01-2015, 10:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
